What parts are those. I have an L29 in the garage that wants to get bored out. It’s gonna end up with after market efi as I got it with a long block. Trying to figure out good rotating assembly and heads to put on it.
Who said anything about rectangle ports??Didnt do bad without the boost.
And Pro 1's are bad for low end torque. Great for mid to high end, but rectangle port heads kill low end
i said, i would want to access what you want to tow (how much weight?) and what your rear axle ratio is first before messing with the engine.
Wrong place for that??? Build crazy engine first and then figure out all the "details" to make it work later.
There's been so many post/questions on this 'burb. 2wd/454/th400/4.10/possible part-time hot shot truck with basic car trailer.
A stock 83 454 would be a pretty gutless wonderMy point is, there may not NEED to be a reason to mess with the engine.
You mean, part time not full time.What you are wanting to do is very impractical. And, if you are looking at towing cars as your main source of income, THIS IS A VERY BAD MOVE.
Update:You may be and probably are correct...but! Where's the fun in that?
@blackandgold51
The L29 is an easy swap, especially in a truck with a 454.
On a general gripe. Have a new pc and it auto-corrects tank to Trump.
- Buy L29 complete with acc, harness & trans or a complete 2wd 98-2000 C2500/3500
- Send harness to be modified & ECM flashed (delete egr/cats, play with timing, etc...normal stuff to make the green folks happy)
- Buy fuel tank out of tbi sub
- Buy GM tank kit (Skunked has tons of good info on this)
- Install everything (yes, I know...easy to say but not complicated. Might need drive shaft shortened and drill a few holes for the trans cross member. All basic wrenching and doable over a long weekend - unless you are @TreeFarm, then you should be able to complete this on the commercial breaks during the evening news one night!)
- Drive & enjoy!!!
Not sure if I hate it more or less now!
