How come I can't spin my front tires with a healthy 454
Didn't work like that for me.
I've tried just spinning one tire while the other remained stationary. Even held the stationary tire with one hand and the d-shaft still did not spin with the spinning tire. Thats why you should spin both tires, posi or not, in the same direction. :waytogo:
Well, I found out I have to move up a few feet for the 4HI to engage, my BAD. :doah:
As for the ratio, the drive shaft spun 1full turn and before the second it stop
between 11 and 12 o'clock, so thats a little over 1 3/4 turn.
So I don't know what that would be, I thought it had to turn 2 full revolutions
to be in the 2's and 3 to be in the 3's
Do you have the sticker in the glovebox still? Look at the codes.
GT4- AXLE,REAR,3.73 RATIO
GT5- AXLE,REAR,4.10 RATIO
GU2- AXLE,REAR,2.73 RATIO
GU4- AXLE,REAR,3.08 RATIO
GU5- AXLE,REAR,3.23 RATIO
GU6- AXLE,REAR,3.42 RATIO
That should tell you too.
John
ps. I still think you should get some manual hubs IMHO... ;) :D
