The dealer part is better than any reman, but if you can find a reman with a lifetime warranty, that may be worth more to you than a genuine AC Delco, as long as you don't find the swap too much of a hassle.
Amen to this quote. Ask me, I know.
When I first bought my K30 back in '96, I had no idea what I was getting myself into with remanned starters.
That truck went thru starter after starter after starter after starter.
After the first few starters, I "upgraded" to lifetime warranty. Again, the same problem with the starters going bad. This time is was just a waste of my time to change them whenever they went bad as I got free replacements every time.
Finally after around the 10th, 11th or 12th starter, I decided it was enough. I bought a brand spanking new A/C Delco starter instead. Never had anymore grinding, nothing. Its still on the truck today.
Problem with the remanned starters is that the seat where they sit on the bottom of the block are worn out. Starters vibrate and rattle. The seats start to wear different angles and depths. Thats the reason for shims, to help take the slack out of them. If you get a brand new starter, theres a very high chance that you will not even need a shim, not one, when you bolt it up for the first time.
Oh yeah, I was getting all of my POS remanned starters from Car Quest, if that tells you anything.
