How do I correctly cut braided stainless steel fuel line
sickquad
Ma
Like the title says. How do I cut this stuff to length correctly without messing up the braid. I'm doing this on a friends motor so I want it to look nice. I know I tape the section I'm going to cut, but what should I cut it with. A hacksaw seems like it may be a little aggresive.
Anyone done this succesfully before?
-Chris
I wrap the spot to cut with electric tape real tight and use a cut off wheel on a grinder. you can also use a hack saw with a fine blade to cut it.
Use masking tape and a hack saw, cut through the masking tape.
An air saw would probably cut it nice but doubtful you have one of those.
Duct tape seems to work the best, wrap tightly. Use an abrasive chop saw or a cut-off wheel on a hand held grinder. Be sure to flush out all of the crap that will end up inside the hose.
Other option is if you have a Beverly Shear available, those work pretty well too.
Cut off wheel it is.
This board is the best. You guys are the only reason I look like I know what I am doing.
-Chris
Yup. I have done the hacksaw method. Difficult especially when cuttin through the rubber part. I've also done the sharp thin cuttin wheel route. Hard to keep straight. I do believe however that there is a hand held spinny wheel kinda like one used to cut flex electrical wiring except rotated 90 degrees. It can be done with either method I mentioned I'd done before. It's not the slickest way but with some patience it can be done.
abrasive chop saw
