I sold the frame and cab and need to get the brake pedal out to stay with the hydroboost system. It is dark and tight up there and I can't tell how the pedal bracket is mounted. Any advice?
Like they said, the bracket has two 15MM nuts inside the cab, two nuts outside. Remove the two nuts holding the column to the lower dash. You don't need to remove the column, just angle it down out of the way. You'll probably need to loosen the clamp holding the lower column end to the firewall. If you have a clutch pedal there are two nuts holding that part of the bracket, and the two pedals come out together.
I will add that this is bunches easier when the cab is upside down.
