How do I...
big jimmy 91
Northwestern Ontario Canada
wire in a switch for my head lights to be able to shut them off when I don't want them on
I mean the way they are allways on even when the switch is turned off
I would like to be able to turn them off when required without having to shut off the truck
BTW it is a 91 jimmy with a 2 light system
/forums/images/graemlins/ears.gif
As soon as I turn the key into the on position the head lights turn on in that half power high beam mode
It is a real pain for someone to back up into lights at night with dirty windows
Well I heard that on older vehicles with daytime running lights, you could put emergency brake on a couple clicks to turn them off. If you still have an owners manual , maybe its in there. /forums/images/graemlins/k5.gif
1.)Find the wire that powers the headlights when you turn on the truck.
2.)Cut the wire.
3.)Wire in a toggle switch.
That way you leave the toggle switch in the on position, and if you want them off you kick the switch off.
Harley
I personally would disconnect the radio dimmer wire from the ignition wire there at the radio. /forums/images/graemlins/histerical.gif That's the most common way you can have the lights be on all the time.
