kodiakisland
Registered Member
OK, I know this sounds stupid, but how do modern 4wds go in and out of 4wd? I have a 2003 avalache that will not go into 4wd. I assume its the actuator because thats what I've been told. Not that I know what the actuator is.
I've had two first generation blazers and a 91 that I've done all the work on myself. I fully understand the transfer case/solid front axle set up and have disassemble/reassembled with no problem. I have never worked on anything modern and don't even know what happens when I push that 4wd button.
What happens when I push the 4wd button? Does that engage the transfer case or does it engage the front axles? I assume my transfer case only supplies power to the front shaft when its in 4wd, but who knows? How about this actuator I've been told about? Is that what shifts the transfer case? Is it all electronic, vacuum, or what?
When I get it working, I'm planning on trading it for something a bit older with less wires. I don't know if that makes me stupid or just old.
