How do remove vent window latch?
KCk51974
Registered Member
Leawood, Kansas
Trying to replace the pitted vent window latch, but can ‘t figure out how to remove. It looks like there is supposed to be a peg that needs to be pushed out. But the peg is missing from the latch, and I still can’t remove. Don’t want to break the glass by pulling or turning too hard.
It’s on a 1970 k5. Any tips are welcome. Thanks.
The pin is probably still in there. That's all that really holds it together. With the pin out mine basically fell apart.
I'd try to use some kind of a mini-press or drill the pin out ,not use a punch & hammer,that vent window glass will be very brittle and shatter easily being 50 years old..
You may be able to use a C-clamp and a socket to press the pin out using a piece of steel slightly smaller diameter than the pin,similar to the way you press a u-joint out with a u-joint press..
I'd search for a spare vent window just in case though..
Good luck!...any safety glass window with a hole made into it is very easily broken...especially old ones..
I have a '93 Caravan sitting in the woods next to my house since 2013,about 3 weeks ago I noticed one of the rear side windows was gone!..it had shattered,and it had a hole made into the glass for a latch,it was the type of window you could pop open one end for better ventilation..
I saw nothing around that may have broken it like a falling branch ,or a stone someone threw--sometimes old safety glass just decides to shatter all by itself for some reason --I remember one hot sunny day at the junkyard I was sitting outside eating my lunch and a side door window on a old Ford Galaxie just "blew out",I guess the heat expanded the glass or something..
Other windows we wanted to break sometimes took several hard blows from a tire iron to break them-so hard we almost couldn't believe it!..it just bounced off several times..we also learned the ceramic off a broken spark plug is one thing that will shatter safety glass like nothing,you don't even have to throw it very hard..
I knocked mine out with a punch, but finding the correct size could be a factor. But it is definitely easier with the vent window assembly out.
I wouldn't try drilling it out, if it's a steel roll pin like what I remember, it won't drill easily.
You can possibly use a section of a drill bit and channel lock pliers in the press procedure that @diesel4me described. I have sacrificed drill bits like that before, a cut-off wheel works well to get a flat end or shorten them. Just be careful if you use more than just the shank of the bit.
Thanks, good info. I am beginning to think maybe I just live with the latches. I removed the windows, took them apart and cleaned all the components. They look great, even with the pitted latch.
so I was able to pass a paper clip straight through the latch pin hole. I haven’t tried to drill out with a bigger bit, but do you think the fact I can put a paper clip through means the pin is not the issue?
Yeah. Paper clip wouldn't fit through the pin. Something else has to be holding it up.
This should prove that it's a roll pin, hollow in the middle. At least that has been my experience. I would have a hard time believing that dirt and shavings would hold it on through all of that.
I bought locking latches to replace the non-locking on my '77 and '79. I can confirm that the pins are roll pins and not a solid dowel pin. You'll need to find a drift punch the correct size (or make one) otherwise the punch will go inside the roll pin.
