vandelay industries
How do you feel, psychologically, about the 4 cylinders, both gas and diesel, in the new Silverados?
i can't quite wrap my head around it----it just doesn't feel "right" to me in a fullsize truck. i think it would be more suitable, even appropriate, in an S-10, colorado etc.
On the other hand:
a) Power-wise, they seem adequate; The common notion these days, is if you were to test drive one without anyone telling you that the truck WAS equipped with a 4-cyl.....
b) Vast majority of tractor-trailers you see on the highway have turbo straight 6's in them. Of course, the difference here is that they are 850+ cubic inches. If the 4's in the silverados were large cube, then maybe i could accept it better.
Rebuttal to the other hand:
a) The 4.3 still has a higher towing capacity than the gas 4. So maybe the turbo 4 is NOT the answer....
b) Even the 6 in the colorado has a higher towing capacity than the gas 4 in the silverado. And this isn't even a 4.3. It's a 3.6 "high feature" v-6.
On the other hand:
..and what happens to the "deactivated" cylinders--do they just add a burden to the other two doing all the work,throwing the balance off,etc ?..
..that truck was a truck,it had an extended cab and a 8 foot bed..
