how do you get the rotor off?
tecton
WV
im stumped
how in the world does the thing come out?
if its a ten bolt you have to remove the caliper, it has 2 allen head bolts holding it on, then pull the locking hub out, once that is out of the way there is a snap ring in the hub, its a PITA, a couple small screw drivers and time can pull it, once its out you will need a 4 prong hub socket, use it to unscrew the hub nut, it will have a washer behind it, a magnet will get it out, then there is another 4 prong nut, unscrew it and the hub/rotor will come off, knock the studs out and the rotor will seperate
[ QUOTE ]
[ QUOTE ]
yeah....i think ill just buy a new car, lol
[/ QUOTE ]
BYE!!!!!
[/ QUOTE ] /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
[ QUOTE ]
[/ QUOTE ]
just what he said but go and buy a repair amnual and it will take you though each step and it is a good way to learn...it isnt that hard just sounds worse then it is
