How do you reseat a bead???
chevyfumes
Court jester
- In Memoriam -
Watch for the muzzleflash!
I managed to catch my tire on fire, but thats about it.... /forums/images/graemlins/dunno.gif /forums/images/graemlins/whistling.gif
i did my tires today, this is what i did, put the tire on the rim, put a piece of wood under it, sprayed eather all over the tire and a trail leading to it then droped a match, then have someone close by with an aircompressor with the tire chuck in it, then when the eather pops the tire on the person with the air hose fills it up , it worked for me
You spray the ether on the tire? I just push the tire down and spray the ether on the wheel (the part inside of the tire) and then the trail across the sidewall to the edge. All of the fire is inside.
Fumes - what size tire and wheel are you working with?
You can also wrap a come along or ratchet strap around tire and pull tight , then fill with good air source ( 12v compressor won't cut it ) /forums/images/graemlins/k5.gif
[ QUOTE ]
[/ QUOTE ]
Just curious, has this method ever been sucessful for you? I have tried this way several times but always ended up getting out the ether. My beads are usually a few inches away from seating because I like to run wide wheels.
Using ether has many variables involved and in my opinion is a last ditch effort to get the tire back on the rim. Some of the variables are the type of ether (Volatility) some won't actually pop but just fizzle out. Another would be temperature and humidity which has to do with the evaporation rate of the ether. The more quickly the evaporation rate the more likely you will get a nice pop. The liquid just burns but the fumes blow. I've had bad experiences with this method. I lost all the hair on my arms and eyebrows were gone. The only thing that changed in my set of variables was temperature and it went from pfft to KABOOM!!! scared the living jaheebees out of me.
/forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gifI think I'll try the ratchet strap....thanks guys.... /forums/images/graemlins/waytogo.gif
[ QUOTE ]
[/ QUOTE ]
Actually the lowest I have gone is 20 psi, so I have yet to lose a bead, I did see someone use it when they pulled over on freeway in 95' with a flat and bead was broken , thats where I learned that trick . /forums/images/graemlins/k5.gif
I've always had good luck with ether. Just jack the tire off the ground, spray some inside the tire (2-3 seconds) spray a trail and ignite it with your favorite flame source. /forums/images/graemlins/thumb.gif I actually have never done it any other way except when I worked at a tire store.
