How easy is a 10B Lock-Right install?
RockinChevy
Chandler, AZ
Inspired by the upcoming BB07 event and Colby's 14b detroit install, now I want to know about the front 10bolt, like the title says....
Will be buying a lockright soon, just not yet.
Thinking of doing it myself to save money and need some insight. I did a search and all I got was 10b vs d44, which locker?, lockright in 14b?, etc... nothing in reference to my question...
Thanks in advance
Take off the hubs (lockouts/drive flanges), wheel bearings, hub w/rotor and spindle. Remove the axle shafts. Take off the diff cover. Remove the small bolt that locks the cross pin (~1/4", sometimes an allen wrench). Remove the cross pin. Remove the spider gears. Replace spider gears with locker. Reassemble.
Pretty easy, the locker should come with directions.
38377k5 said:
Take off the hubs, wheel bearings and spindle. Remove the axle shafts. Take off the diff cover. Remove the small bolt that locks the cross pin (~1/4", sometimes an allen wrench). Remove the cross pin. Remove the spider gears. Replace spider gears with locker. Reassemble.
Hmmm.... so easy a caveman can do it? :wink1:
Thanks, I'll keep it in mind :thumb:
pauly383 said:
Come over , bring beer , I will show you how , just like someone showed me the first time :thumb:
Sounds good, Paul
I'll hit ya with a pm when I get the locker. Thanks man!:thumb:
After this, I'll pay it forward when someone else asks for help.
