How far does a DRW 60 stick out?
blazd88 said:
i have pics of mine with hummer beadlocks and drw60 and van width 14 bolt it but wont let me post for some reason.
cool well whenever the forum is back up 100% and it works I'd really like to see those
here is a bad pic of mine froim the front i'll post another one when the galleries are back up. mine is a 75 k5 w/ drw 60f & a d70hd rear. ditched the drw hubs off the 70 & put srw hubs on it, it is a .5 inch or so wider in the rear than the frt now, which i am not happy w/ but will live w/ for now. h1 wheels & 42" tsls
Drw
I cannot cut and paste into a reply for some reason so I had to type the pic in manually so as soon as I dont have to do that I will post up more pics.
This is a DRW D60 front and a van width 14FF rear with no spacers as of yet. I love this setup so far with no regrets or problems to this day.
You could also machine down the drw dana 60 hubs to srw hubs.. there is a section on this in the pirate4x4.com dana 60 bible.
Put a cheap set of dually hubs on the rear
How does one install D60 hubs on a 14BFF?:crazy:
But they run the same bearings as a D60 so you can run the front hubs wich are wider. That is what I mean. They are very cheap on Ebay.
It doesn't matter. You cannot bolt up the 14BFF axle shafts to the D60 hubs.
hummer rims are 50$ a pc and you can't even get the weld on kits for that
The weld on kits are available on this site in the Vendor's forum for $50/set.
Here's a couple of pics of Layne's (K5BLT4FUN) old rig.
He was running DRW D60, Van 14BFF with wheel spacers, 12bolt Hummer wheels (unmodified) on 42" TSLs.
