Huh?...
superwrench said:
Heres a little food for thought. Most plugs are not desgned to burn oil so consiquently the fouling of the plugs. The little trick we use is in our older race car motors we put in lawn mower plugs, alot of these are designed to run or burn a gas/oil mix. Cuts down on plug fouling. Now I know someone is going to say its a dumb idea, but it works. You just need to get a plug that has the right length threads, right heat range, your parts people can help with this. Example-- In the older chevy heads we used a champion J8C, or a J6C plug.
I doubt that would help,but if it worked for you,more power to you!..as far as I know those plugs are not "special" because they can be used in 2 stroke motors,and are no different than automotive plugs..(My brothers '41 Stude uses J-8 plugs as OEM equipment!)..Champions foul faster, and wont recover from fouling ,more than any other brand,IMO--once they stop firing,they are done!..(OK,except maybe the Bosch Platinum ones,they wont fire right out of the box sometimes!).. fouled AC plugs will "clean" themselves after awhile,but Champions are dead forever once they foul..
I hate Champion spark plugs..I repaired small engines for most of my adult life,and many of them only needed the Champion plug tossed in the trash ,and a new plug of some other brand installed to get them running!..when you have only ONE plug,it needs to be a GOOD one!..
They sell "Aldor" brand spark plugs at an auto discount store here,that claims to "fire in oil",and are reccomended for old engines that guzzle oil and foul the plugs..I have tried them,they DO work!...I never had to change the one I put in a smokey straight six I had,that would foul "normal" plugs in a week or so..they sell several different ones,for whatever kind of engine you have..
Also,you can buy "non foulers" at parts stores that screw in the head and the plug goes in them,they increase the heat range and sheild the electrodes from oil and extend plug life..but they will reduce power a bit..they say to use them only on the cylinders that foul the plugs,and not more than half of the plugs (4 out of 8 on a V8 as an example)...I've had many old Chevy's that needed them!..
I used to swap a fouled plug into another cylinder that didn't foul the plugs,and put the "good" plug in the "fouled" cylinder..the heat from the "good" cylinder will eventually clean the fouled plug,and you can avoid having to replace them so often this way..
Adding stuff like "Lucas" motor treatment or STP Oil Treatment,"Motor Medic"and similar oil thickening agents will help reduce fouling and oil burning..but I'd wait until warm weather before adding that type of stuff,in cold weather it could lead to hard starts or engine damage from the oil being too thick to pump quickly when first started..
