I dont dare!..
I keep my 4x4's under 85 mph--and even at that speed they didn't "feel" safe!--my tires are used take offs from a boneyard,and none are "hi speed balanced"...all my GM 4x4 trucks started shaking after 85 mph,and I had no desire to be a stain on the road!...my 72 K5 hit 100 mph once,but who knows how accurate the speedometer was..I had to see if my newly installed SM465 made any difference in acceleration--it did,but only on takeoffs!..I would not trust any 4x4 over 85 mph much..they just aren't designed for high spped safety...and a lifted truck?..even WORSE!..
I think the fastest I've ever driven any of my cars or trucks was my 69 GTO--I once had a Barracuda pull up beside my goat on the highway,and the guy was flooring it and letting off,like he was enticing me to race!..then he got behind me,so close I couldn't see his headlights!..
I floored the GTO,wound it up over 100 mph in second gear (TH400 with 4.10 gears!)--and I held it there until third gear ran out..the speedo was buried at 130 mph!--and the car was shaking so bad I thought it would fly apart!
--the Barracuda was WAY behind,and he exited the highway behind me--must have been embarrased!..
My Ford Contour isn't any slouch either--despite it having a tiny 2.5 "Duratech" V6,it puts out 170 HP!--it has a 4 speed overdrive automatic,and 3.77 gears..its doggy under 2500 rpm (which is the RPM its at when doing 70 mph!)..but floor it,and that little motor winds up like a chainsaw!--the redline is 6200 rpm on the tach!
---I've beaten a few Mustang GT's off the line with it!...
I was boxed in by two 18 wheelers in a construction zone about a week ago,and nearly got squashed in it!--so as soon as the lanes opened up,I booted it,and held it to the floor...it wasn't long before the headlights of those trucks looked like they were miles away--when I looked at the spedometer,it was over 110 mph,the tach said 3500 rpm!...I have no doubt it would bury the needle at 130 mph,I had plenty of pedal left!..but I was about to stain my shorts,the car was shaking pretty badly..my front wheel bearing is a bit noisy,so I thought it was unwise to be going that fast..and it felt more like 200 mph for whatever reason--I guess smaller cars "feel" faster!..
I rarely speed,unless road conditions make it a lifesaving manuver--I prefer to go 60-70 tops..so just about everything else passes me on the highways..
