How Hard is It To Come By Conversion Hubs For A DRW to SRW?
Yes, Warn or any other locking hub can be picked up cheap. I think some are for sale now in the For Sale forum.
As others have suggested, you can still run the DRW wheel hubs, install lockouts, and run wheels with a lot of backspace and you would be OK. I have seen SRW wheel hubs sold for around $450.00 by one of the vendors in the link Jek gave you. /forums/images/graemlins/thumb.gif
To convert a DRW Dana 60 to a SRW all you have to do is switch to SRW bearing hubs. Everything else is the same on both axles.
They sell SRW Dana 60 bearing hubs new. They run about $400 for the set.
Used SRW hubs sell for close to what new ones go for.
Nobody will trade SRW hubs for DRW hubs because DRW ones are worth only about $50 and are plentiful and the SRW ones are expensive.
If you plan to run beadlocks in the future just keep the DRW hubs and run hummer rims.
Pretty easy. Give us a call. We have them on the shelf for $207 each. We also have the studs, they're $2.96 each. The only other thing you will need is to drill the rotor out just a little to fit the studs. Everything else will transfer into the new hubs, locking hubs, bearings and races, etc. We have new bearings also if you want to replace them. We don't have them up for online ordering so you'll have to call us.
