I'm thinking about getting a slip yoke eliminator for my 208 (let's not get into a 208 vs. 205 debate!) and would like to know what I'd be getting into. I'd be doing the work on my back. Here's kind of what I think:
1) Drain fluid
2) Remove front/rear driveshafts
3) Remove shifter linkage
4) Remove speedo
5) Remove 4WD indicator
6) Support trans somehow
7) Remove 4 (?) adapter bolts (these look hard to access, also trans side or t-case side?)
8) Buy a trans jack at harbor freight and put it under the t-case
9) Unbolt crossmember
10) Slide t-case back and bring it all down together
What did I miss or get wrong?
1) Drain fluid
4) Remove speedo
