I got the 400SB in my 77 GMC K2500 so hot once the exhaust manifolds were glowing a dull orange!...I had been pushing deep wet snow across a large parking lot about 300 feet long,a good 20 minutes,when I noticed more steam coming out from under the hood than you'd normally see from melting snow,or the exhaust getting splashed on...then I smelled coolant,and saw the temp gauge was pegged..it peuked out of the overflow bottle..after it cooled off I refilled the radiator,and it only went up to 180 degrees,the 195 thermostat was now stuck open I assumed..
That engine got overheated probably 10 times,until I learned you could "lock" the fan clutch spring so it would stay "on" constantly--until then,every time I drove the truck with the plow on it over 30 mph for more than 5 miles ,it would peg the needle and start peuking out of the overflow tank..I had tried numerous thermostats,leaving it out,etc,to no avail...locking the fan clutch solved the problem 100%..for free,after wasting money and time on it..
I thought sure I'd at least blow a head gasket,with the 400 SB being the most "fragile" when it comes to overheating,and having siamesed bores..but it never used any coolant,or got any in the crankcase..
I remember a friend's '72 Nova that had a 250 six getting so hot one night on the highway when we were returning from a night of partying ,that the exhaust manifold and part of the head it bolts too was pumpkin orange,when we pulled over to see why the "temp" light came on,we saw the lower hose had ruptured at the water pump,a nice rip in it 3" long..when it blew,it took out the bottom row of tubes in the radiator too,it was all gangrene and paper thin,many fins were missing too..
Not wanting to have a cruiser pull up behind us and possibly get pinched for DWI,my friend decided to just get back in the car,FLOOR it,and drove it the remaining 8 miles to his place..we made it there,but it sounded like it had a piston so loose it was flopping around in the cylinder,it was pinging BAD the whole way there too--when he went to shut it off ,the engine actually smoothed out and ran BETTER that it did with the key on,and the pinging stopped!..we had to open the hood and close the choke to smother it to shut it off!..the exhaust manifold was orange and the head was a dull red color...I got my hand burnt pretty good holding the choke shut long enough to snuff out the engine..
The next day we found a used radiator and got a new hose,we put them in,and I told my friend,not to be too dissapointed if the engine was junk,if it would even run,it might have spun bearings or at least a blown head gasket..but to our surprise,it started right up,the lifters clattered for a few minutes,then quieted down one by one--after 15 minutes,it ran just as nice as it did before the overheating dilema happened..he drove that car another year before he sold it...said he never added any coolant to it either,it stayed full...
..I gained a lot of respect for straight six Chevy's after seeing that one withstand that abuse..
