So a few weeks ago the passenger side (rt) exhaust manifold showed the signs of being cracked/broken (the usual ticking, etc. It was in the typical place - right between the two front runners. Knowing that replacing this on a 27-yr old truck could prove to turn into a nightmare of fatigued/rusted/broken bolts, as visions of e-z-outs danced in my head, I had to invent a way to carefully remove these bolts.
- Get all the usually junk out of the way to expose the top of the exhaust manifold (brackets, plug wires etc)
- Get out the drill and a long (6" or so) drill bit (probably a 1/8" - I didn't honestly look)
- Locate the areas of the exhaust manifold just above the bolt journals that the bolts go thru that attach to the head.
- Drill holes perpendicular to each bolt journal somewhere around the middle, taking care to intersect the journal. Drill thru until you the bit get into the journal. You want to stop short of drilling into the bolts/studs.
- Insert the handy-dandy red tube that comes with your can of PB Blaster into each of the holes and spray until PB Blaster squirts out of the holes. It doesn't take much. Your goal here is to actually get penetrating oil to where it will actually do some good - the threads going into the cylinder head. Just spraying it on the bolt heads couldn't possibly get any to the threads.
- Let this sit for a while and maybe give the holes a second squirt.
- Get out your breaker bar and a rubber hammer.
- Put the breaker bar and a good 6-point socket on the first bolt/stud.
- GENTLY tap near the end of the breaker bar like you are trying to break the bolt loose. You may have to tap for a while, and gradually increase your tapping force, but eventually you'll start to feel some movement. Keep going until the bolt is starting to break free. DON'T get over-zealous, as putting too much torque at one time on these old heat-fatigued fasteners will surely snap them.
..thing worked great though,and didn't shatter..
