How Important Is Is To Seperate Power And Signal Cables In Amplifier Wiring
seschev3 said:
Remeber, ground is your friend and should be 18in or less.
very true. just went thru my wiring this weekend. my engine whine was from a ground that was insufficient, or too long. it was about 2ft long, i cut it to 10" and drilled a new hole, fixed it right up. i was hoping the fatter cable(used 4ga)would allow me to run a longer ground. i know your already done w/ your install but i thought i'd throw that in here.
Bad ground is 99% of the time the culprit in engine noise... whether it be a bad ground @ the deck (stock grounds almost always suck) or a bad ground @ the amp.
alway run them separately,
a ganunteed way of getting noise int he system
I use the higher quality stuff and still run them seperately. Power cable down one side of the car and RCA cables (Patch cords) down the other.
