i saw the thread where ira did the calculations, but im still not sure how many i should use for my tires. ive got 42x14 iroks on H1 rims. will 2,000 be enough or will i need to use more? thanks
01maroonz71 said:im wondering the same thing for 42x15tsl's.
but it looks like going a tad overboard doesn't hurt anything....are you gonna mount your own tires man??? or take them somewhere??
primerk5 said:You guys are using Airsoft Pelets to balance your tires internally???? Dose this work better or worse than that dust stuff they used to put into the tires???
How dose this work???
i dont see why it would matter. whatever gets you to the weight you need and is easiest to put in/remove, cheapest, softest, whatever floats your boat. fwiw i use golf balls in my 42s. some people just use water/antifreeze. imo it doesnt matter with this large of a tire.Ned Kelly said:The air soft pellets come in several weight sizes .12gr (standard), .20gr, .25gr, .28gr and I think .30gr. I've read the .20 and .25 are the recommended weight bb's to use for your tires. Anyone else heard the same?
I don't know why.83_Shortbed said:so you use them in place of or in addition to wheel weights? cant say I recall anyone doing this before
Is that right 42x14 ?ive got 42x14 iroks on H1 rims
Dafey said:I read about it quite a while back in either Petersons 4wheel & offroad or Offroad.
