How many gallons is your fuel cell?
skyyk5
N.E. PA
I have a new fuel cell (half keg) and just need to weld on the fittings. But It's 15.5 gallons I think. Will that be enough for the day at RC? The truck is the trail rig in my sig.
Most common half kegs like Bud or Coors or Miller will be 15.5 when you get into littler breweries then they start to vary a little but not to much. I feel like that might be a little small I would feel more comfortable with 20 but you can always just carry a jerry can
I might be able to get another half keg, for 31 gallons. Could make it so I could switch between the two. Then I'd really look like a drunk.
PA is probably different from the rocks here in the west but I probably don't even burn 1 gallon an hour during trail rides.
I'm currently using the stock K5 31 gallon tank and it hasn't been below half full for more than a year, I simply don't use that much fuel even in a couple days of trail riding. I fill it up when I have the chance just to make sure I don't run out.
I'm still leaning towards switching to propane with two 10 gallon tanks, I foresee no problems (I will run a bigger tank on the trailer to fill between trails if needed).
