Working on a 56" spring front front and rear on the K5. How many leaves do I want to leave in the front spring packs? I am not running overloads, and since these springs are from a 3/4 ton, I definitely want to take a few out.
Also, should I be putting bolts back through the little alignment brackets that are riveted to the bottom most spring? Seems like they would big time limit droop, and I am going for maximum flex.
My truck has a turbo 6.2L diesel / NV4500 / NP241 and a 3/4 ton 10 bolt front differential, just to give you an idea of how much weight I have up front.
