I just got back from a 150 mile trip, and according to odometer, did about 13 mpg going there via highway nonstop and around town until jumping back on the highway and re-filling. According to odometer, though, which I know is slow. I'd guess I'm probably getting 15mpg on long trips like that (lotsa highway). 33"'s, 350 TBI, stocker.
Like many others have said, I agree; you just need to keep filling the tank and tracking how many gallons you dump in each time, and how many miles you've gone since last fill-up (I know this works; my sender's malfunctional). The key is fill up, though.
Also, running down to empty isn't good on FI trucks, because it will run the in-tank pump dry, which shortens it's life (been there too many times before deciding to just keep the tank full).
On my old K5, my speedo cable died, then my fuel sender wire broke off the assembly (actually the pump power wire broke off, but I sacrificed the sender wire to pump power). Try figuring out mileage with that combo!!
TX85GMCguy:
You might actually have the 28 gallon tank, and not the 31 if you can only refill it to 27 gallons after going dry. If you definately have the 31gal, I'd say yank out your sender assembly and make sure somehow the pickup/inlet isn't short, and not reaching the 4 gallons in the bottom of your tank.
Ratch
**<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
