Yes, another, how many of you question. lol
How many of you are running 1.5" spacers on your 12 bolt rear axle?
Every time I need to trailer the blazer I have to swap out one of my front tires for a skinny spare just so it fits on the trailer.
Wider front axle better trackingEven thou I run smaller spacers on the front, my front is still wider than the rear. Maybe it;s a stability / handling thing.Wider front axle better tracking
I skipped the spacers on my suburban. I went with a complete axle swap to a 2005 Silverado disk brake rear end. Six lug, disk brakes, parking brakes, and it is 4 inches total (2 inches per side) wider than the stock axle.
Is this a 14bolt?I skipped the spacers on my suburban. I went with a complete axle swap to a 2005 Silverado disk brake rear end. Six lug, disk brakes, parking brakes, and it is 4 inches total (2 inches per side) wider than the stock axle.
Yep, modern 10 bolt (8.6 chevy) rear end. Disk brake rear out of a 05 silverado. Wider width, just removed the bump stops on the axle. The new spring pads go where the bump stops are on the axle. The u-joint is the same also. The parking brake was pretty easy to match up to my burbs cable. A brake hardline extension to switch sides from passenger to drivers side allowed me to even run the silverados brake lines. Find my "pure chevy sex" thread and get the BEST brakes you can do on a half ton square body.
ETA: also moved and raised the shock mounts, but kept their relative location.
