How many teeth in a stock np 208 drive gear
h0wl0ngcanitbe
Washington
like the title says what is the number of teeth on the drive gear of a stock 208 tcase? i need to replace the driven gear to get my speedo corrected, ive been doin some research on the job seems easy enough. any help would be great.
It is dependent on your gear ratio in your axles. There are more then one speedo gears out there because there is more then one ratio of gears in axles. They are color coded I believe, but I don't know what ratio gears are what color.
Harley
ya, just adding to what he said. i dont no how much you no but..youll have to do some research and find out how close ur tires and gears r to stock, and say u have 4.88s with 35s then ur speedo would be spinning too fast with the stock gear, so ull have to get a bigger speedo gear then ur stock one.
thats what i figured, i was just wonderin what driven gear im gonna need to get to replace my old one. i guess ill just crack it open and pull it out. shouldn't be too tough but i live in a neighborhood that doesn't take to well on mechanical what not on the street. i was hopin to just order the new gear and save myself a step. thanks for the help though.
