Well, I have ANOTHER issue with my TPI swap. Last weekend my truck was running fine. Today, I go to crank it up and my fuel pump is not cycling on with the key in run or cranking.
I pull out my multimeter and it doesn't work, swap the batteries and still doesn't work. So I grab my test light, get my wife to feel the relay to tell me if it is clicking and it is, so I use the test light to see if I'm even getting power to the pump. IIRC the purple wire is for the dash, so I checked the white wire. It barely lit up the test light. So I guess I need to fix one of my multimeters to see how many volts are going to the pump.
Is it supposed to be a full 12v or is it cut down somewhere along the way?
