How much emergency gear do you haul around?
Mastiff
Tucson, AZ
Every now and then I try to get serious about making sure I have all the appropriate gear on board to deal with break downs and emergencies. I'm talking about tools and fluids, spare parts, emergency stuff like med kit and survival gear, recovery equipment like straps and clevis hooks, etc etc. Once I piled it all up (and not counting stuff I still want to get, like a few extra tools, better plug kit and a 12V pump), it takes a pretty significant amount of space. I started buying those Rubbermaid "action packer" totes to organize everything, and it's going to be tough to get by with fewer than four of them. The Blazer can soak it up, but it would eat most of the space in the Jeep. The K5 carries the spare inside too...
Anyway, I was curious if other people are hauling so much around. I've really got a pretty minimal set right now.
I have a tool box on my truck that will be packed completely shut.
I usually carry enough for a oil change, 6 qts of trans fluid 3qts of power steering fluid. 64oz of brake fluid and 5qts of gear oil. And a few gallons of coolant.
I have a toolbox that has a wrench and socket to fit every nut/bolt, couple sets of pliers, crescent wrench, screwdrivers hammer. Then I have my high lift, one strap, spare tire, tire tool, gallon of coolant, gallon of hydraulic fluid(use it in my tranny, t-case, and power steering) gallon of oil and a gallon of 80/90. Then I have a box with tire plugs, hose clamps, a hose repair kit, tape, zip ties and a few small parts.
I do keep a first aid kit and fire extinguisher but they are strategically placed to not take up room and be easily accessed.
I like to make things universal like using hydraulic fluid and same length front and rear driveshaft. Working on a rear bumper to attach spare tire, tire tools, and jack. Also going to build a compartment underneath to hold my tools and spare fluids. That will completely open up my cargo area.
On a side note switching to one tons increased my weight and decreased my ground clearance but I used to carry enough parts to rebuild the front axle inluding shafts and a hub/spindle.
Yeah if you are driving around town you "possible" bag is going to be different then if you are going wheeling, and different if you are going camping.
When I'm just driving day to day around town I carry my spare tire, lug wrench, jack, fire extinguisher, 12v air pump and a small tool bag. When I'm wheeling, I carry pretty much the same stuff as was said in the earlier post.
I carry a lot as well. Fills 2 large ammo cans and a truck bed tool box made for a midsized pickup. Plus a few things stashed under and behind a rear seat in the cab.
  • Aluminum floor jack that I've used way more than I would have guessed
  • Coffee can full of spare tie rod ends
  • Various pieces rubber hose
  • Spare upper & lower radiator hoses
  • Spare accessory belts
  • Bulb pump
  • 2 different size c-clamp
  • Old & new style spindle nut sockets
  • Assortment vacuum caps
  • AN caps & plugs
  • Assorted bolts, nuts, & washers
  • Spare power steering pump since mine runs brakes & steering
  • Steering pump pulley puller
  • 2 spare poly bushings
  • Oring assortment
  • Full basic set of tools
  • 100ft nylon rope
  • Bottle jack
  • Torque wrench
  • Multimeter
  • Assortment electrical connectors
  • Assortment of fuses
  • Square tip shovel
  • 2 recovery straps
  • 2 or 3 d-rings
  • Tree saver strap
  • Snatch block
  • HI Lift jack
  • 3 gal gas can
  • Air impact wrench
  • First aid kit
  • Shop manual
  • Spare ignition module
  • Spare 1410 & 1350 u joints, a few of each
  • Receiver mounted vice
  • 20ft 3/8" chain
  • Assortment hose clamps
  • Jumper cables
  • Jackets for all 4 family members
  • 2 gal 50/50 antifreeze
  • 2qts trans fluid, oil, and p/s fluid
  • Qt brake fluid
  • Small can WD40
  • Roll shop towels
  • Hand cleaner
  • Drain pan
  • Wheel chocks
  • Fire starter kit
  • Couple power bars
  • Couple spare relays
  • Spool 12ga wire
  • Can of zip ties
  • 2 fire extinguishers
That's all I can think of right now.
Everything stays in my truck all the time or I'd forget to pack it.
  • Bulb pump
  • AN caps & plugs
  • Oring assortment
  • 100ft nylon rope
  • Bottle jack
  • Torque wrench
  • Multimeter
  • Square tip shovel
  • 2 recovery straps
  • 2 or 3 d-rings
  • Tree saver strap
  • Snatch block
  • HI Lift jack
  • 3 gal gas can
  • Air impact wrench
  • First aid kit
  • Shop manual
  • 20ft 3/8" chain
  • Jumper cables
  • Qt brake fluid
  • Small can WD40
  • Roll shop towels
  • Hand cleaner
  • Drain pan
  • Wheel chocks
  • Fire starter kit
  • Couple power bars
  • Spool 12ga wire
  • Can of zip ties
Sounds like you must be related to Russell. I thought he was the only guy who carried 1000lbs of tools and spares.
I carry quite a bit of stuff.but probably not as much "survival" things as I should,especially in winter..I have enough tools to do most minor roadside repairs like change a belt,alternator,fuel pump,starter,etc,and carry some spares of those items if I have any--I try to carry an electric fuel pump too--also have an extra set of locking hubs,and most of the fluids I'd need like oil,P/S and trans fluid,coolant,etc..and an empty gallon jug and 5 gallon pail,those can save your butt if you need water from a swamp to refill a radiator..pieces of rubber fuel line of all sizes and clamps,to patch up a popped tranny cooler line ,etc...
I want to get a full sized floor jack and one of those 12V or cordless impacts to change flats with..its bad enough wrestling a 120 lb, tire and 8 lug rim out of the bed (I'd never mount the spare under the truck in the factory carrier,screw that!)...never mind having to unscrew 8 lugs that come off stiff every last thread most of the time,and almost getting killed trying to jack it up with the stock jack,or a bottle jack.,while semi's blow by you inches away at 70 mph!...getting too old for that crap!..
The biggest problem in a single cab pickup,is where to put all this stuff..I have a toolbox in the bed stuffed with most of this stuff,behind the seat is several lengths of chains,a small 12V winch,ratchet straps,more tools,spare belts,and the front floor on the passenger always has a box of extra oil,filters,come-a-long,and snow brushes,etc..so having a passenger ride with me,is usually not possible...
I could litteraly fill a trailer with spares like a tranny,steering box,and other "stuff"..
I have considered mounting some ammo boxes I have on the stepside bed between the cab and fenders,also thought of mounting the spare tire there,so it wont be buried under cargo in the bed next time I get a flat..(like 10 minutes after loading the bed with a few dozen pallets for firewood,then have to remove every last one to get to the spare!):doah:..
I have also considered just taking off the old stepside bed thats getting pretty shabby and putting my 8' flat bed on it that I kept off my last GMC,that has an electric crane setup on it--and put those ammo boxes under the flat bed..but that'll need a new floor and paint,and I am torn whether the truck is worth that kind of labor now..
I could put a "box truck" body on my truck (I have 12' one I use as a shed..)--and fill it with all this stuff..they suck for visibility though..top heavy..not worth the effort !..
I liked my van,you could toss a lot of stuff in that thing,and still have room for humans and survival gear...here having a "zero-zone" coveralls and some extra jackets and blankets with you in winter,could make the difference between living and dying,in a blizzard scenario..after seeing how vicious it can snow here last year,I respect Mother Nature a lot more than I ever did previously...
Having some non perishable food,crackers and water with you isn't a bad idea either...I carried a propane camping stove and propane in my van at all times...its nice to be able to make hot soup if you get stranded--try that in a pickup truck!..more than once I broke down in my plow truck (or got it stuck !) .while doing a customers parking lot,and had a long wait before a friend could come help me out..
Around town: spare tire and AAA roadside card :D
Nearby trails: few extra tools to fix small things, get off the trail, then AAA roadside :D
Moab & Rubicon: almost everything but my spare T-case lol. You aren't looking to make it road worthy, just back together enough to get off the trail. So packing a torque wrench, feeler gauges, etc wont be used and will be a waste of space. At camp is where the rest of your tools should be. If it's the Rubicon, you end up carrying more. If you drive your rig home, you carry more, but not on the trail if you can help it. More weight = more strain on the truck and more crap in the way.
Also, spare tire inside brings the suck, unless you remove the bench seat. I often do that if I don't have passengers for an event.
Good replies. My dream is to have my stuff somewhat portable and swap between Jeep and K5 depending what I'm taking. Would have something separate for K5 specific parts when I get to that. I recently took the rear seat back out. Without shoulder harnesses, I don't plan to drive my kids around anyway. When they get older they can go one at a time in the driver's seat. I'm scheming to weld up a custom spare carrier that mounts to the seat and seatbelt mounting spots (no new holes) with the tire on end, then connecting some rails or something to allow the Rubbermaids to be strapped down. I hate stuff bouncing around, and it's worse with the line-X since it slides and bangs around more noticeably.
