How much lift do you have in relation to your springs?
In my underwear
Administrator
Author
CO
If you measure from center hub to the bottom of your fender lip in comparison to what your springs are?
In front my measurment is 26.25" with a 2.5" spring... seams like it sits higher than a 2.5" spring.
The rear is 25.5" with a 4" spring.
Also.... body lifts, zero rate blocks, longer shackles??
Are you trying to isolate the spring lift from everything else that can add lift?
-G
Yes, just trying to get an idea on springs only.
I have about 27 5/8" up front with 3.5" ORD springs and their HD shackles. That should make it 4". I have a big block, no winch, and I weighed it before Steven did the order.
The rear is 26 1/4" at the rear with 56" no name springs.
Oh, and this is on my '70, we won't look at "Bruiser" .... poor old K5....
