When putting the fiberglass top back on, how tight do you guys crank down the bolts?
German torque of goodentight.
If you still have the locating pins in the back you just need to snug them but if you don't then they need to be tight enough to hold the top from slidingthe reason I ask is because all the bolts were all Frozen on removal, two of them had to be cut, if it's not important I'll just do four finger tight?
