Dave1
Registered Member
I have a 2006 GMC 2500HD 4WD Duramax pickup truck that has a burned out daylight running light bulb. This is the small single bulb in what appears to be a twist lock bulb socket directly below the headlight assembly. I cannot get my hand down in there to get the socket out of the reflector where I can change the bulb so I assume something has to be removed to gain access to the small light bulb socket.
Can anyone provide info and directions what I have to do to get to and change that bulb?
Thanks, Dave
Thanks, Dave
