how to add horsepower
If you use vortec heads then you also need a vortec intake. I beleive there is some other things you may need but i dont know all the details. Vortec Heads I just found that sight so read up.
Later
vortec heads! iv built roughly 300 pair of these for Scoggin-Dickey here in Lubbock and they make a huge difference(stock or not). Look into part #8060ra. They have bigger valves,springs, cut guides, and bigger push rod holes. /forums/images/graemlins/waytogo.gif
what real world hp gains can be acheived by this swap. Also I've heard for the same amount of money aftermarket heads can be bought for the same amount with a better result is this true. Reason I ask is when my warrenty (sp?) is up on my crate I was going to either swap in vortecs or go with aftermarker or a port and polish. For the money which is the best way to go. BTW I have a 97 with a 350 vortec and love it so I know vortec heads are good but is there better for the money?
Pro-topline heads are probably a better bet in most cases.
No matter what you want to do, the springs will handle the lift you want (within reason) the studs are screw in, the pushrod slots should be big (unlike Vortecs) and a few other things.
I never really got a clear picture of what the different pro-topline heads have to offer. The problem is that while Vortecs made some major changes to make the power they do, the other "small" changes (rail type rockers, no exhaust crossover, centerbolt valve covers, intake bolt pattern) end up causing other problems that can add cost quickly...DEPENDING on where you want to start and end up.
If you can get pro-toplines with the fast burn style combustion chamber, exhaust crossover if required for emissions, and improved intake runners, with a "standard" intake bolt pattern, I think they would be a better deal.
Unfortunately, it's like buying a new car or computer. There are MANY good choices out there, but all have their up and downsides, just have to weigh all of them. Pro-toplines end up costing about as much as Vortecs, but if you buy the exact equivalent, the pro-toplines have better features.
I got 10 extra horsepower when I put this bad boy on. It only took me 2 minutes install time too
What did you install? I may have missed it...I'm lookin to pep up my 305 also...thats why i ask. (money is the issue, so buyin a new crate engine is not in the near future!) and are those TBI spacers a good idea...seem reasonable priced ($65)...i just don't know if its hype or if they really give a bit of a boost.
It was his ck5 windshield sticker /forums/images/graemlins/histerical.gif
