Does this technique work? I’m trying to bleed the clutch on a 2002 Silverado 2500.
I don't see how that works. Didn't watch part 2 for results.
I have not bleed a 2002 2500, so some assumptions on my part.
Bleeder screw at slave cylinder?
If so get a large plastic syringe 3-4 oz, load that up with fluid use rubber vac tube zip tie to bleeder and syringe. Open bleeder, remove master cap, place rag over reservoir, maybe catch tray under.
Then slowly inject fluid through bleeder.
This will push all air out the top.
Yes - that's where it came apart aka the OG problem. Got a replacement cable, line etc as shown to replace it. The part that chaps my hide, the cable I'm replacing is maybe 6 month oldwhen you say cable... do you mean the tubing is disconnecting at the yellow/gold connector in picture ?
This is good - the old timer explained it very well. However as luck would have it I'm still in the same boat w/ a spongy pedal. These methods have been used to bleed the system.This was on ls1.com forum recently and was a really good method. Video does some explanations and demos.
The master is about 6 months old - worth replacing it?
