How to cal. cubic inches?
Cornfield creations
Jasper, Indiana
I wanted to know how to calculate cubic inches on a small block.
I have a 327, bored .060 over, 9:1 aluminum flat top pistons and double hump heads, 64cc chamber.
Bore x Bore x Stroke x .7854 X the amount of cylinders (8 in this case).
A 327 bored .060" is now a 336.6
That's a weird formula. It seems to work but it's weird.
I've always used the area of the bore (pi x the radius²)xthe strokexthe number of cylinders.
Where do you get that .7854 constant from?
It appears to be based off of the square root of 1/2 of the bore/pi (hence the double multiplication of the bore)
Man, that's complicated. :confused:
I'll stick with regular geometry. :D
Thats about the extent of my knowlege of it - If you want more detailed info than that I can ask my 1-semester-away-from-a-math-degree wife :D
Nah. I'm good with old "pi r squared". That's the way I was taught back in 1989, so that's what I'm going to use!
area is pi * radius^2
If you use bore, you are using the diameter.
area is now pi* (diameter/2)^2
Factor out the denominator and you have:
pi*diameter^2/4
or, diameter^2 * (pi/4)
pi/4 is........................................
.7854
brought to you by the 'magic of math'!
-Ben
pi*diameter^2/4
.7854
-Ben
I knew it was something like that but havn't done math like that since 1998 so I couldn't work out the equation..... :D
I always forget the formulas , but I always remember every .030 is around 5 cubes for an 8 cylinder ( round up for advertising ) :thumb:
