Over the years Ive tried many methods of mice control to keep them out of the Vette, trucks, shop and garage.
The first step is to take care of accessible entries.
Plug the holes, remembering the little bastards love to chew on things.
Here are some of the ways I've tried and the results IME
Steel wool: slows them down but it don't get rid of them.
Electronic wave devices: they must be deaf cause it don't drive them away.
Scented dryer sheets: they thanked me for the nest padding.
Irish spring scented bar soap: they used it as an appetizer.
Glue traps: caught a couple of mice on these but they have gotten away from them too.
Bait boxes (D-Con): these work well eventually when they've ate enough, but the usually go die somewhere, then you have to search out their coffin to rid the stench of dead carcasses.
Water bucket traps: peanut butter bait leading into a bucket of water works well, but a mess to clean up after they sit a few weeks.
Baited spring traps: these work well, I use peanut butter for bait, these need to be checked every few days/weeks depending on how many invaders there are.
Peppermint oil extract: I use 2 ounces of extract mixed with 16 ounces of water and spray it with a mist sprayer bottle inthe affected areas, and any entry points. This has worked very well, haven't had any mice in the traps since I started this method a few months ago. I have sprayed the area under the vehicles, around door openings and the interior.
It needs to be touched up about once a month but no mess to deal with and it smells better than dead carcasses!
What have you tried and post your results
I've yet to see them eat the mice they catch, usually just find the bodies in our yard.
