How to change front u joints??
dallassnowman
Forney, Texas
I 've got a 82 blazer diesel. And the front u joints behind the disk brakes need replaced. But is it real hard to do? I've replaced the auto hubs with warn hubs.
if you want good step by step instructions with pics, go over to pirate and do a serch in the articals.
it will help!
Pull off everything from the knuckles out off, then you can slide the axle shafts out threw the center of the knuckles to replace the axle shaft u-joints.
