How to? Changing front output shaft in 205
BigOrange90Jimmy
Wilmington, NC
Just found out that my 205 in my truck has a 10 spline front output. I need to either convert it to the 30 spline shaft so that I can run my flange, or just find a u-bolt style driveshaft. Help me out fellas.
I've never torn into one of these t-cases, so my knowledge is limited without any manuals. How do I do this and can it be done quickly?
I did my swap while in the truck. Its not that hard. Its alot better with two people.
First, drain the case........ dont ask, i forgot
second, take off the yolk. Impact gun works nice. For that i cheat and put it in 4wd. Be sure to put it back in 2wd, it might not matter, thats just how i did mine.
Third the cover right behind the front out put, take it off. This will leave you looking at the back of your front output, youll see a huge gear. You should then be able to slide out the shaft, a collar and a washer (i think) should fall off. Note the order, i dont remember.
Now, when your putting the other shaft in, have someone with long fingers hold the washer from the front.
I just dove into the project one night. and everything still works. Its a bit interesting putting it back together. Youll do fine,
This might not be the best "how to" but its easy
your goin to need a strong impact to get it off.i dont know what my dads is rated at but it wasnt enought to get mine off.
its pretty easy/straight forward... there is prolly a write up somewhere here or on pirate. Only prob I had is that there is a big snap ring that is a royal biatch without the right tools. I spent an hour trying to get that thing off... then threw up my hands and took it to a local shop, they popped it off for free in like 10 seconds. lol!
j
i've got the nut and the yoke off. my 3/4" drive sockets and ratchet took care of that.
i'm just trying to decide what to do.....
good article on how to rebuild...
here's an article with pictures that I used to rebuild my 205. As long as you don't mind it's a F**D site... :rolleyes:
Clicky
Scott
