FrankTheDog
Registered Member
I have a 85 K30 camper special, most trucks I see seem to have a flat spring in front. Mine has a bit of a curve to it. I bought the truck the way it is and the previous owner had no info on what the suspension is.
How do I determine how much if any lift it has now?
My plans for it are to switch to dually hubs up front and a dually D70 in the rear to run H1's with a 38" tire. Cross over and high steer with assist are in the plans also.
This is going to be used as an offroad work truck more then it will be used for just for fun wheeling. Mostly for hauling firewood out on skidder trails and other fairly heavy loads.
I would like to add only enough lift for the clearance with trimming of the 38's.
Any pointers? I've searched and can't really find the answers I need.
Thanks, Frank.
Thanks, Frank.
