The trailer isnt built yet. Im having the shop that is making the frame add some tabs on the trailing side of the axle so I can add shocks. Once I get the trailer, I can just drill the frame and add upper shock mounts. So I can basically add any length I want, just determines where to put the mounts. But how do I determine length or better yet, where to put the upper shock mount. Im guessing I want the mount in a place that would put the shock right in the middle of its compression stock, so it has room to compress and expand. Right?
Not sure if it matters, but the trailer will be "Spring over axle" for extra lift.
