k20
3/4 ton status
Ok, so I have an electrical drain in K20. If it sits for more than a week the batteries (dual) are dead. I have unhooked the batts from each other and let it sit and only one goes down (the one hooked to the starter/factory wiring) and the other stays up. To rule out a bad battery I swapped their locations, and it still drew down the one hooked to the factory wiring (the other has the headlight relay harnesses, extra lights, electric compressors, etc hooked to it).
I read online and people were saying to hook a test light between the battery and the negative cable and pull fuses til the light goes off.....Well....if I hook in the test light, it doesnt light up! Also it doesnt register on my multimeter. WTF am I doing wrong?
