I hate to be "that guy" but I've been searching all morning and cant find the thread that talks about swapping hubs around to get the proper WMS to WMS to run H1's on a 14-bolt
[/FONT][FONT=Arial, Helvetica, sans-serif]Type A SRW / Van 14 bolt hub[/FONT]
[/FONT][FONT=Arial, Helvetica, sans-serif]Type B hub on right, Type A hub on left[/FONT]
[/FONT][FONT=Arial, Helvetica, sans-serif]Type B hub on right, Type A hub on left[/FONT]I dont want to run spacers, not if I can get the right combo of factory parts to get me where I need to be
Not sure if I'm following everyone on this thread.You run dana 70 hubs on the 14 bolt and it sets the wms the same as the d60 dually.
Brakes is a custom job.Cool!! what about the brakes?? do you have to swap backing plates too?
I dont want or have time to swap in a Dana 70 . spacers may be my only option then
What years newer 14bff have a different width? What width are they compared to the older ones?Not sure if I'm following everyone on this thread.
If you use a DRW D60 and want to run H1's, you need either a D70HD or a newer 14FF from the newer body style trucks with IFS and it won't matter if its 2 or 4wd. The newer 14FF's are the same (or real close) width as a D70HD.
To get the rear tires tracking the same width as a DRW D60, you need to swap on SRW bearing hubs from a SRW 14FF.
If you put on DRW bearing hubs from a D70HD onto a SRW 14FF, then you're putting the 14FF right back to the stock width of a narrow 14FF which also shares the same bearing hubs as a D70HD.
Still want to use H1's? Find a D70HD or a newer 14FF.
Best thing about the D70HD's is that you can go lower in gear ratios than anything a 14FF offers which is either 5.13 or 5.38. The big 70 can go way down to 7.17.
Not sure exactly what years they started but my dad has a '97 K3500 crew dually and its got the wide 14FF.What years newer 14bff have a different width? What width are they compared to the older ones?
Here are my 3" hubcentric/wheelcentric for H1's, ask for Junior at http://www.motorsport-tech.com/wheel_adapters.html
What truck are you puttin um on? I've been slowly gathering parts for my build and I'm using H1's. For reference the truck as it sits now has 33x13.5x16's on it on 16x9" wheels. With my 3" spacers I will be 1" wider total wms to wms. So it should be just about right not sticking way out (maybe 1/4-1/2" per side) but not gaylord inside the fenders.....
Send me a PM if you have anymore questions, I scratched my head about this topic for a while....
