How to get Engine static out
Interference generated by an EM/RF source will get into the radio VCO/audio circuits without some kind of filter. This is true whether it is AM [cb] or FM commercial communications equipment. Most modern electronics have this filtering built into the DC power supply to almost all but eliminate it and are usually overengineered to compensate for a range of variables. CB's however, are relatively "low tech" by comparison to commercial grade communications and some older and newer models [cb's] do not incorporate a filter of some sort or not enough. A "dirty" supply line will also cause interference in almost all applications without an active filter of some sort. In mobile applications, I've seen a leaky diode in the alternator or a borderline voltage regulator do some nasty things to supply voltage, all the while providing no other indication of a fault. Replacing these components might also help the situation. Floating grounds or ground loops will also wreak havoc.
I am a strong advocate of proper wiring with the proper gauge and connection procedures. However, a seemingly miniscule vehicle deficiency can be attributed to most challenges. The gauge of the wire is SOLELY for current carrying capacity, not EM interference. Actually, the increased surface area of a larger gauge wire causes it to receive MORE external interference, in theory. A "legal" CB only draws a few amps during transmit. The "ground" for the antenna is ground...period. RF and DC ground are the same. The antenna needs a ground plane in order to properly radiate RF energy. A fiberglass or insufficient plane area requires either a base loaded or elevated feed antenna to provide this plane.
The best solution to PERMANENTLY fix Harley's problem if he wanted to maintain "key on" power is to utilize a relay to switch supply voltage when the ignition is turned on and the use of a filter of some sort. This will guarantee a trouble free radio. OR...he could get another unit /forums/images/icons/smile.gif. Ensuring that his MSD box is properly connected would also be advisable...
OK...I'm done. Just my $0.02
Everything on the MSD is connected properly. I am going to try a ground wire to the battery, but most likely will be getting the filter so solve my problems. I don't like to have my CB connected to a hot wire, just in case I forgot and left it one. I have done it before, and luckily for me it was only for short periods of time, and my truck always started.
Z3PR, said it all use a ground strap and make sure it is less then 3feet long or its pointless. Oh and dont move or antenna to fiberglass it will make you swr's jump up over work your radio. Which will cause your radio to run hot and possibly burn up your pills or burn your board.
