I have a broken tap in one of the timing chain cover bolt holes....I think its 1/4 inch. I've tried a cobalt drill bit, carbide cutter, acetylene torch, a punch, and a small pointed chisel. This is broke off about 1/4" below the surface of the block, so I don't think a welded on nut or something of the nature would work. I have used that before, but feel the 1/4" hole, and hardened tap would be a challenge for me to get to work without welding to the block too. I'm not sure how long this thing has been in there, I thought it was a broken bolt to begin with, but after cleaning the hole out, I can see the shape of a tap in there.
Any other ideas?
Any other ideas?
