Threaded inserts. Have replaced the bad nuts and have not had any issues.
I'm more concerned with the bad cages than bad nuts. Any thoughts there?
Did you check the Amazon link?
Do they look anything like those?
Colby, I suspect the answer is you gotta bend new sheetmetal and make your own cages, then spot-weld 'em on from underneath. MAYBE you could JB-weld 'em, maybe.
-- A
I have access to a sheet metal brake, so those would be easy to make, I suppose.Used these on my 74, called it a day http://www.apiclamps.com/shop/?p=productsList&iCategory=6
Some of you are crazy. These should just be repaired to work like the originals. Why hack up the bed rails for something experimental when the factory design often works for a few decades/100k's of miles? It looks like the little box holding the "cage nut" (not the same thing some people are suggesting in this thread) could be bent a little to fish the thing out. Then build a new one from a nut with the same thread, some flat stock and a welder. Or get them out of a junk truck or something.
If I was making my own, I would set the length of the flat stock so that the threaded hole can't get hidden under the sheet metal - because that is annoying.
He stated before he didn't want to weld the rails, that kind of leaves out the obvious "right" fix. But he explained his reasoning, so the intent is to work around that constraint.
My plan is to just get in there and weld it. The bedrails are thick enough that I don't think I have to worry about the paint for tacking the cages in place. And I do have a sheet metal brake, so it will be easy to make new cages. I was just wanting to hear what other folks may have done, or if there was a supplier out there that made the cages, because I'd be willing to pay a dollar a piece or so just to not have to bother making the cages.
Lots of innovative solutions in this thread though. Thanks!
The tailgate mechanism might need some lube, but I find that it has more to do with the tension on the latches when the tailgate is closed. Sometimes the adjustment that gives the best sheet metal lines doesn't let the thing "unlatch" very easily. This is easy to test by flipping the latches in by hand with the tailgate open. Then it's usually really easy to pull the handle. You can try messing with the striker locations to see if it makes a difference.Also, my tailgate handle is getting harder to use. I need to open things up and see what's going on in there, but I figure I might just tag this question on to my post too.Any ideas? It's like I have to pull up on the handle more on the driver's side than I used to, and typically have to push in on the gate harder than I'd like to, to get the gate to release and come down.
Sometimes the tailgate starts hitting somewhere before it's latched. This adds tension. Look at the clearance from the inside. In a perfect world, the tailgate seal is hitting all at once. You might need to adjust the hinges. Most of those holes are slotted.
As for the handle, the mechanism gets bent because it's just folded sheet metal and the pull rod is off to one side. The same thing happens in the rotating part in the center of the tailgate. The high force you have to put on the handle starts bending stuff so the handle action gets higher and higher. I recently tore out the handle mechanism and the rotating one, straightened them and welded in reinforcements. It's still hard to pull the handle, but at least the handle pulls straight and won't run out of travel before the tailgate releases.
Good info! Thanks!
I do have access to a spot welder, so I could try that on the cages, I suppose....
