how to read the R&P?
vw62rag
topeka, KS
hello this may sound dum but im tryin to figure out what size R&P i have on some axles i have and some may get. is there a tech area anyone knows of online that has this info? i have a D44 with a BOM that reads 603455 ( i dont have the numbers off the ring gear yet ). and i have a 14B rear end that has GM 327722 10 41 5 84 on the ring gear, and a 10B rear end that has 2 GM 123512 6 13 40 12 84 on the ring gear. please help
thanks!
Last two groups of numbers are the date code. This diff was built in May 84. The two groups before the date code are the gear ratio. This diff has 10 pinion teeth and 41 ring gear teeth. 4.10's.
This diff built Dec 84, 13/40 (3.07's)
HTH
Rene
thanks rusty! but how did you get 3.07 out of 13/40? and is there a way to tell what gears are in a axle by the BOM? (i mean i know they could have been changed but im jus tryin to find out what came with it from the factory) i have a D44 with BOM 603455
thanks again
thanks again
It's a ratio, 13:40 ... or in this case, 40:13 ... 3.07:1.
Yes, your BOM likely will tell you ratio... but I can't find any good lists for '44's, sorry.
-- A
