how to remove door pannel
tuggy24g
Registered Member
Newtown PA
I was trying to remove my door panel to replace my side mirror. I got all the screws out, but now the panel is still suck. Like it is glued to the door. Is there something else I am missing? Not sure what to do
Thanks for the help
Brad
Thanks for the help
Brad
I removed mine on my 1990 the other day and all the screws were out but it stll wouldn't budge. I finally got aggravated with it and just snatched it and the top piece of the door panel goes down in the channel a little bit and it was hung in the window channel. Hope that helps you out!
Door panel clips too. They make clip tools for them but a long flat blade screwdriver can work IF you are careful. Sometimes, especially on these older trucks, the clips will rip right out of the panel and stay in the door. After that the panel will not secure properly to the door and starts to get all flappy when you close it.
Pull the panel back a little bit to find a clip. Insert tool between panel and door and pry on the clip to pull it out of the door. Move on to the next clip. Gets easier as you go.
