So you really dont need to twist the wires together? Simple solder joint laying ontop is enough?
Or use butt connectors and heat shrink.
Is that considered the right way?
I personally unwind them a touch, interlock them, rewind them in their natural direction and solder them like that. Dunno if it's better or worse but it's just the way I learned.
Butt connectors are less reliable than wire nuts (which shouldn't be in your car either). They can be helpful as a solder splice for joining 3 or 4 wires together, though. You pull the plastic off, crimp then solder.Or use butt connectors and heat shrink.
This is the method that had no people bashing the bagejus out of...
from what I have learned is that when you make the X with stranded wires, it is called a "Lineman Splice" and is used for stranded ONLY. What they say is doing this will weaken stranded thus not recommended.
so ill be doing this way.
The right way is to remove the ends out of the relay plug. Put new ends on the leads to what you are powering and solder those on. Then plug them back into the plug. No joint at all to be worried about.
Push the little clip on the side in and pull the plug out. Might be a clip on each side. Then post a picture. The wire retainer on the back needs to come off. I can not see in that picture where the release is.
Ill mess with it but it is waterproof so most likely it is "sealed" in thus not going to come out nicely. ill take pics later...
