How to tell what tranny/engine/transfer case?
Big Skinny
Registered Member
Pelham, Al
What are the options for transmissions and transfer cases from the factory on 89-91 K5"s
What are some easy tell's to determine which are which?
What is an easy way to differenciate between a 305 and a 350 while in the vehicle?
350/700r4/np241 very likely. look in the glove box at the sticker that is hopefully there. it has some useful information on it.
from 305 to 350 read the casting numbers on the block. very easy to do.
Should be a 350/700R4/NP241. The 1989 model NP241 is the ONLY year that used a speedo cable after that the speedo's are electric.
