How to test for bad lifters??
Mudstud
Memphis, TN
Have a 350 with the intake off and would like to know if there is a test I can do to one, two or all to determine if they're bad.
I take them out and make sure they are flat on the bottom, not concaved in.
This is my method:
If you pull it out and it comes out in little peices or you find it in the bits on the bottom of your pan then you know its bad! /forums/images/graemlins/rotfl.gif
[ QUOTE ]
[/ QUOTE ]
Actually that's not true, they're supposed to be convex, slightly.
I'd do the cam and lifters as a unit--haven't had much luck putting new lifters on an old cam,even when the lobes looked ok.Every small block I've had needed a cam so far,with only one or two exceptions--they had new cams installed before I got them!.You can get a cam and lifters for under 100 bucks--its worth it!.
