GsxrMike
How do you guys weld the seams of your roll cage that you can't get to? Like the upper cab corners etc. I did some research on the subject and didn't find much on that issue.
Also I am not a trained welder but I have a miller 170 and I have welded several things that held together fine including then end on to a 2" hydrolic ram on a trencher. What tips do you have about welding tube. I read not to get it "to hot" because it will make the metal brittle.
As always -
As always -
just a matter of time till you end up with a nasty sun burn or some nice burn scars...
